One Conax Embedded card reader 6000 channels (TV and Radio) programmable Stream TV & Radio channels to your Android devices via local network! Click here for more info! Two High Speed USB 2.0 Connections Ethernet Connection & USB WiFi Support (Ralink RT5370 chip only) YouTube videos RSS Reader & Weather Forecast Functions (Ethernet or WiFi connection required) Channel Streaming via local network to Android Phones & Tablets Channel Recording to External Storage Devices (optional) Timeshift support Channel Recording & Timeshifting Simulteniously (optional) Channel switching time less than 1 second True-color, User Friendly On-Screen Display (OSD) Full Picture In Graphic (PIG) function Electronic Program Guide (EPG) for on screen channel information Subtitle supported Teletext supported by VBI insertion and software emulation Parental lock facility by channel and program event Program and Channel information transfer from receiver to receiver Satellite Blind Scan & Fast Scansupport Unicable Support DiSEqC 1.0, 1.1, 1.2 and USALS Compatible Full HD (1080p) Output via HDMI Exciting games embedded Multi-Language support Software upgrade support via USB, Network, RS232 Power Consumption in Stand-By: <0.5W
TECHNICAL SPECIFICATIONS Tuner & Demodulation Tuner Type: DVB-S / DVB-S2 Input Connector: F-type, Connector, Female Signal Level: -65 to -25 dBm LNB Power & Polarization: Vertical: +13V/+14V, Horizontal: +18V/+19V Current: Max. 400mA (Overload Protection) 22KHz Tone Frequency: 22±1KHz DiSEqC Control: Version 1.0, 1.1, 1.2, USALS Demodulation: QPSK, 8PSK Input Symbol Rate: 2-45 Mbps, FEC: 1/2, 2/3, 3/4, 5/6, 7/8 and Auto
System Resources Main Processor: Dual Core 600MHz CPU Flash Memory: 16MB DDR3 RAM: 256MB MPEG TS A/V Decoding Transport Stream: MPEG-2, H.264 Input Rate: Max.120Mbit/s Aspect Radio: 4:3, 16:9, Letter Box Video Decoding: MPEG-2, MP@ML, MPEG-4 part 10/H264 Video Resolution: 720*480P/I, 720*576P/I, 1280*720p, 1920*1080i, 1920*1080p Audio Decoding: MPEG-1 layer I/II, MPEG-2 layer II, Dolby digital Audio Mode: Left / Right / Stereo/ Mono Sampling Rate: 32, 44.1 and 48KHz
Power Supply Input Voltage: Free Voltage (100-250V AC 50/60Hz) Power Consumption: 30W Max Stand-By Power Consumption: <0.5W
A/V & Data Input/Output SCART A/V: Video RGB/CVBS output, Audio L/R output RS-232C: Transfer rate 115.2Kbps, 9 pin D-sub Type USB: Two USB 2.0 slots S/PDIF: Optical HDMI: VER1.4, Type A Ethernet: 10/100M RJ45
Вы не можете начинать темы Вы не можете отвечать на сообщения Вы не можете редактировать свои сообщения Вы не можете удалять свои сообщения Вы не можете добавлять вложения
